I had to do the high idle mod switches and i have to wait till the engine reaches something about 140 before i will move it and its fine.My truck is hard starting when cold. It's OK in the morning when plugged in but after work (when temps are below freezing) it sputters until I hit the gas then stabilizes. It is putting out alot of white smoke when sputtering. Once it stabilizes it runs fine. Any ideas?
it sounds like the diaphragm is torn inside your VP, as for it failing you won't know until the smoke pour out and your start throwing codes. Does it pour out white smoke for a while when its cold out, the tale tell sign is when it smokes when its plugged in.Grid heaters are cycling OK. It will stabilize as soon as I hit the gas. It's kinda like starting a carbureted gasser.
I was worried about the VP? It's got 200K miles on it and had a weak lift pump behind it for an unknown amount of time.
I guess what I should have asked is if this could be a sign of the VP failing?
