I was towing a 25' snowmobile trailer today with the smarty jr set on tow and a couple times when shifting from 5th to 6th the clutch pedal was very hard to push in.
What would cause this??
Try replacing the slave cylinder, do you have a stock clutch? Make sure your clutch fluid is up also.
Mine is hard to push after the clutch slips with the smarty on 100. But if I pump it once its back to normal. Might be your clutch slipping.
It only happened right after accelerating in 5th or 6th and the clutch did seem to slip slightly? What would cause the pedal to be hard from the clutch slipping? What would be a good replacement clutch? It is a stock clutch. I might do nozzles and a turbo down the road someday. Thanks.
Banned
valiar DD clutch mine works good:thumbsup
If the friction disk gets to hot and melts to the pressure plate that might cause it to stick. Also if the through out bearing seized up or something that might have something to do with it. Other than that not sure why it would do it only in 5th and 6th unless you are fueling the heck out of it and lugging it at the same time causing an increased amount of torque at the clutch in 5th and 6th. I would recommend a SB clutch. They make a great clutch and depending on the HP that you would like to see they will provide you with good service.
Yep, kinda "melts" itself together. Then pedal is hard to push. Sounds like your clutch may be going bad or atleast getting weak.
