2" inch lift is using your stock control arms tho right? a 4" inch lift might have to swap those arms out and put round ones in instead of the stock I-beam looking control armsMy 35" BFG MT's on H2's clear by aplenty with just a 2" lift. You should be OK!
Thats right. The stock wheels have more backspacing, pulling the wheel in closer to the control arm. The h2's have 5.5" so it kicks them away from the control arms but tucks them in enough that they stay out of the fenders.Yes sir. That's correct. I still have the stock control arms. No rub. Should be better with aftermarket arms. Yours kiss the arms cause you have stock wheels right?
yes, that could also be another problem, my rims but its fine, its nothing serious, and my bad, i overlooked the title with the h2 rims, (different offset). :butt:Yes sir. That's correct. I still have the stock control arms. No rub. Should be better with aftermarket arms. Yours kiss the arms cause you have stock wheels right?
