what range should the tranny temp, boost pressure, and egt be in for a
3rd gen cummins with goerends 48RE with billet input and output shafts, smarty, tst, intake and 4'' exhaust. thanks for any help.
My tranny temps usually runs between 150-190, depending on what I am using it for. Towing it usually stays between 180-190. The boost pressure is electronically controled on my truck and I usually see constant 30-32psi under full pressure and it will spike to 35. Hope this helps.
Are you talking what are the maxes you wanna see on the gauges??
Boost: 45 psi (stock) and then your turbo is not very efficent
EGT sustained max 1250, spike max 1600
Tranny keep it under 200*
My Trans Temp runs about 140* (Sender in the pan)
Boost pressure will vary depending on throttle and load.
EGTs with your setup if you are running a stock turbo will be out of control.
outta control as in the engine wont last too much longer or what? what is the best way to reduce the egt's with this set up?
