1 - 4 of 4 Posts
what do gsk springs do
i have a 96 cummins 4x4 auto bd tourque converter valve body wider shift bands and ceramic clutches
number 10 plate and 100 injectors use it every day so what should i do next
intake and exhaust done
On a 24 valve they will do nothing.
Ed Font, did you even read the post? Last time I checked a 96 had 12 valves. :confused013:
Yeah, what 97 12v Jones said. :agree2:
bull.rider, did you search at all?
"Governor Spring Kits (GSK)
- Stock governor springs de-fuel starting at about 2200 RPMS, it's quite noticeable. Governor spring kits allow your IP to fuel up to 3000, 4000, 5000 + RPMS depending on what kit you buy. The popular choice is to do a 4K GSK. It fuels nice and hard throughout the RPM range. If you plan to do a 4K GSK and REV ABOVE ~3250 RPMS, YOU MUST ALSO UPGRAGE THE EXHAUST VALVE SPRINGS TO 60LB SPRINGS! Many kits come with both sets:
4000RPM GSK Governor Spring Kit with Heavy Duty Valve Springs 5.9L 12 Valve Cummins"
I found that here. http://www.cumminsforum.com/forum/94-98-powertrain/287781-beginners-thread-read-first.html
1 - 4 of 4 Posts
