1 - 10 of 10 Posts
I started getting a mild vibration, and grinding rattling noise (box of rocks like) from the front of the motor a few weeks back. Mainly around idle speed, and low speed accel and decel. It would go away at about 14-1500 rpm.
Turns out it was not the water pump, but failing bearings in the idler pulley assy and the fan support bearing/housing. The warning is that these are not covered under the powertrain warranty.... and the parts bill at dealer list was almost $900. :banghead:
So if you sense a change in sound and vibration, get it checked out while still under the bumper-to-bumper coverage.
I would expect it to be covered under the engine warranty.
after reading it, wow, stuff has changed. I thought the engine warranty included everything attached to the engine back in the 90-2000's. Now its a smaller list.
2014 2500-3500 diesel warranty
I had that bearing of bad on my 2006 with somewhere around 150,000 miles on it. I actually drove it that way for a long time, maybe a year. Sometimes it would be mild growl and sometimes louder and louder when cold like in teens or below. Finally it got loud enough that I decided to change it out while on a road trip in Oregon. When the small independent repair shop told me the price, I was shocked, he showed me what the cost of bearing from a Dodge dealership was going to be and I just swallowed hard and said I need it done and he scheduled it for the next day. That night for kicks I searched it on this site and found someone had 3 bearings for about 1/4 the cost and it was same identical part number. Next day when I took the truck in I showed the owner (remember small independent shop). He couldn't believe it. When I came back to pick up my truck he told me "I ordered the bearing from the guy you found on the Cummins forum. I went ahead and used the part from Dodge but I'm going to take the other when it arrives and return it to Dodge and get credit. So I am only charging you labor plus the cost of the part you found with a small mark up".
I love small independent shops and honesty....I would go there again and anyone near Central Point Oregon that wants to know who it was, PM me and I will share.
Saved me about $350 bucks if I remember right!
Yup, I will be doing a lot more self troubleshooting now for most things, before trying to claim against the power train warranty.
Reactions: gsbrockman
Funny this thread came up, not a cummins engine, but on one of my international dt466's, I just lost the fan hub bearing two days ago. Left the guys stranded on the side of the road when it seized up and threw all the belts. $1000 tow bill, and the bearing was $680 cost, plus labor and two belts and there back on the road...... My advise, if it's making noise, replace it!
I called my service department after reading this and asked if I had it fail as you described on my 2016 would it be covered under the power train warranty and I was told it would be covered. I was told everything power train is covered except for the service items. Now I am confused as to what's covered. I read the manual and I must have missed where the idler pulley is excluded. I'm sure your right, but I was told I only needed to pay for service items on power train for the first 100k
Buyer of stuff..with OPM
I'd bet you were baboon'd by dealer.....call Ram customer care and run it by them......
Sam
1 - 10 of 10 Posts
