1 - 2 of 2 Posts
My truck came up with a p2609 code this morning and I discovered that the ground cable running from the relay to the battery ground was broken at the connector. I’m trying to find a replacement wiring harness since the wire looks like it has an inline fuse but I’m not having any luck. Has anyone been able to find a replacement one of these or am I stuck trying to remake my own?
· Admin/Mod
A ground will have no fuse. are you sure what you are talking about? if it is a ground just replace the connector.
1 - 2 of 2 Posts
