I had the trans rebuilt and the fluid is gray not red oil isn’t burnt also it is “flaring” engine revs alittle between sec and third. I took the truck back to the trans shop and they didn’t know what would cause the issues any ideas?
Obviously they screwed it up, take it back.
Reactions: Russ Roth
Sound like the shop has some explaining to do, definitely not good
Does the fluid smell like ATF, assuming it's not burnt?
It's hardly the heat exchanger has failed and is allowing coolant into the trans oil?. I've seen it many times in engines and the oil turns grey.
Reactions: Clunk
Yup, water.
Heat up a piece of metal and place a drop of fluid on it. If it pops and crackles then it is water.
Reactions: utahtrapper
