well i got all the power i need and torque, but even with all the goodies and $$ put into my engine and tranny, my truck literally tops out at 90mph, any1 have easy mod like gov. springs so i can get a little more top end
so your saying as you unscrew the tension count the clicks from the stock ones and reinstall with the same clicks and basically forget the height?Isn't leaving the inner spring out for the 4k kit what they call a "3200 GSK"?
According to Tony597fitter (a regular poster here) and Weston (injectors) that setup can (or does) cause hard starting issues over time. ?? Not sure though, it could be a different spring combo for that custom setup. I'm not sure.
I just installed my 4k kit yesterday and my buddy free-rev'd it up to 3600 or 3700 RPM and no audible signs of anything but smooth revving (IOW, no valve slap). I kind of looked at him like "ARE YOU F'in CRAZY?!?". But hey, he's a licensed diesel mechanic with an excellent reputation.. if anything happened, it would've been on him.
Anyway, that 4k kit is unREAL!!! I can't believe how much it woke up my truck. And it fuels hard ALL THE WAY through the RPM band, not just up top.
When my bud was doing the GSK, he told me there were factory marks that helped him line up the new kit at the exact factory location (spring tension). He also counted clicks when removing the stock gov's. Then used the exact tension for the 4k kit. He also used veneer calipers to measure the depth, (in all instructions for GSK installs) but honestly that is the stupidest way to do it!! It's not accurate and there are better ways.
We didn't have to adjust my idle at all. It was the smoothest GSK install I've ever heard of. Very happy with it.
:thumbsup: thats how i do mine, i take a measurment with the calipers to have a good reference point, but the clicks should get ya where you need to be. its best to make a screwdriver that will fit over the center nut for easiest goings, but not a deal breaker. i use a pencil magnet and long screwdrivers and go through the fuel plate hole, most like to go thru the side of the pump.so your saying as you unscrew the tension count the clicks from the stock ones and reinstall with the same clicks and basically forget the height?
