I installed the gauge today, and everything went ok. Except I had to fight annoying leaks all day. I tried to get the air out the best I could. How do you bleed these gauge's the proper way? Also I've got 16-17 psi at idle, is this good? Thanks
Only one way to know for sure, get a fueling box on the bad boyIt also has 12-13 psi under full throttle. I'd probably be under 10 psi if I had a fueling box on it huh?
