1 - 13 of 13 Posts
AMERICAN RACING 20 X 10's!!!anybody know what the rims are called?whats the backspace,because i have no clue.I DONT LIKE THEM,they DONT STICK OUT as much as i wanted!maybe new tires will change that or a spacer right?if so which ones?
its the offset of the rim..other than wheel spacers, the only other way to fix that would be to change rims for a larger offset
spacers are safe. I used to have 1/4" spacers when I ran large tires on a stock rim. The wheel spacer is fitted between the wheel and the hub. Im not sure what the largest is you can get
If those are American Racing..... They dont make them anymore. i have never seen them and i was looking at American Racing for the last 4 months figuring out what wheel i wanted. Maybe they are another brand with American Racing center caps or an older style not made anymore.
Discussion Starter #8
well the Hub Cabs go with the rims design..just waiting to lift the front end with adjustable shocks/leveler.and then hopefully spacers!well see what it looks like,though still
NEED MORE INFO ON HOW FAR RIMS WILL STICK OUT AND WHAT SIZE SPACERS?AND SAFETY AT HIGH SPEEDS?
Ive actually been looking at spacers.. im runnin 22X9.5 XD Monster w/ +18 offset and my 37" Toyo MT's are 14" wide. They rub a bit on the control arms at full lock... i think i could run about a 1/2" spacer and be fine...
i have never been a fan of spacers.... if u want it to stick out get diff offset.
ive seen 1" spacers thsat were fine
they bolt onto the hub just like a rim would and is torqued to spec...the spacers have their own studs on them and the wheel is torqued to spec on the spacer lugs
Discussion Starter #13
okay look AT THESE PICTURES!!20 X 10's AND THEY BARELY STICK OUT!!I have 305/50r20 which is a 31" tire.and i want to make know WHAT SPACER CAN I FIT?IMMA GET A LEVELER AND LIFT THE FRONT END HIGHER THEN THE REAR!!
WHAT WIDTH SPACERS WILL MAKE WHEELS STICK FURTHER YET ON A LOCK TURN NOT HIT WITH LEVELER?31" TIRES 20 X 10 RIMS
1 - 13 of 13 Posts
