1 - 20 of 46 Posts
Hi,
Well today I got my truck dynoed, and I made 472.5Whp and 1121Nm at 45psi of boost
The mods I have done is:
Afe air intake.
Afe exhaust manifold.
Dual CP3
Airdog 165.
Batmowheel turbo 66/74.
120Hp injektors.
Bullydog Trippledog tuner with crazy larry 2.4 I think.
So my guestion is what should I do next?..))
I was told that the turbo was good for 800Whp??
how much boost do you make on thre street? dynos can be disappointing if you cant load down your truck enough to get the turbo really going, especially with a single
I`ve actually never seen more than 43psi on the street..
We did a pull in 3rd than it made 409wh, then we tried one with OD and it made 472.5Whp..
But how much should I get with that setup?
Truck is by the way an earlie 2004.
Mabye crazy larry and bullydog isnt the way to go? Should I buy a smarty mabye?
Well it could've been the dyno not reading correctly. But if i remember correctly, crazy larry didnt run that well on early 03-04 trucks.
3 footin' through life
Yeah thats super low for that fueling. Snag one of these smarty's you see in the classifieds all the time.
World Champs!!!
We don't use Nm, 1121Nm is 826.7lb-ft
Should be higher, but it's all in the dyno and operator...
Discussion Starter · #10 ·
I've heard that too, but I had to try..))
And it was pulling much harder with crazy larry than the stock bullydog tune.
Discussion Starter · #11 ·
Yes I was told that it wasnt easy to get a good read because of the auto trans..
I see you dont have a pressure box, dont you turn up rail pressure when you get bigger injectors or am i wrong here?
I would think a smarty SSR and lots of time on the dyno would be ideal for you.
Take it to the track to see what it traps. Thats a pretty accurate guestimation method.
Got a vid of the dyno? Also, what brand/type of dyno?
Discussion Starter · #15 ·
I was thinking about SSR and a shift kit for the trans..)
I havnt got any pressure box no.
Should be at higher boost I would think also. Any smoke at WOT? What are you seeing as far as EGT's?
Discussion Starter · #18 ·
Yes got a vid on my phone, and a graph.. Will try to get it posted tomorrow..
Discussion Starter · #19 ·
Not any smoke no.. The trans are buildt here in Norway.
1 - 20 of 46 Posts
