good question?What did it cost you, and did they recomend a shift kit or valvebody also?:drool2:
what he saidWhat did it cost you, and did they recomend a shift kit or valvebody also?:drool2:
There are a couple companys making a valve bodies, IIRC.$1000. + install fluids etc. There really is no shift kit or valve body for the 68RFE yet. That is kinda the holy grail that everyone is trying to work out for these transmissions.
I bought the 10 blade 2 disk TC. It got installed this morning by Richard over at Browns diesel. I highly recommend him.:thumbsup:
The new torque converter rocks!arty018: It totally improves the trucks response. When you give it gas it goes. It is so positive you don't even notice lockup. With the crappy stock TC lockup felt like another gear since rpm would drop 300-400 rpm. Now I'm not turning power into heat.
Everyone says something different. I've read there isn't enough line pressure and from others there is plenty. I've read the clutch packs can't be beefed up. Other people have said they can. I've read the shafts are good to 600 HP. Others say 700 HP.where is the weak point now? Shafts? Pump? TCM?
Good info. My question now becomes, is the 68RFE even worth trying to modify? If the line pressure is increased, can someone with 500 rwhp do a 15-20 PSI boosted launch - similar to what the Ford Torqueflite and Allisons can do (up to a certain HP of course)?The tranny makes about 160 psi of line pressure and it does it quickly. If you try to up the pressure, the computer will just bring it back down. The overdrive clutch packs are just too small. These are the gears you are going to have the max load in when you are playing around.
As for the dual disc against the triple disc, the dual has some more room for dampening. The triple rattles a little bit right now. Dave is working on that. You can get the dual disc cheaper, but that would mean it wouldn't be as low of a stall in it. The 10 blade that Dave offers it more expensive because of the cost of the stator, but it is totally worth it on the 68rfe. These motors naturally produce more torque as compared to the 5.9L. More torque means lower stall to make it feel right. If you put the same stall into a 5.9 and a 6.7 and they were making the same hp, the 6.7 would feel like a looser stall.
Since all of the pressure is controlled by the computer, it would be nice if the Marco could effect the trans pressure limit. I know the guy is crazy busy, but it will help these 68s live longer. Another thing that could be done is to find the right resistor for the electrical to make the computer think the pressure isn't high enough.
Isn't Torqueflight a Chrysler trademark name for their transmissions or did Ford purchase the rights to use the name?Good info. My question now becomes, is the 68RFE even worth trying to modify? If the line pressure is increased, can someone with 500 rwhp do a 15-20 PSI boosted launch - similar to what the Ford Torqueflite and Allisons can do (up to a certain HP of course)?
That's why I'm so hesitant to jump on the ATS 68RFE transmission. Without being able to control it electronically, it sounds like a waste of money.
Is the only hope to do a 48RE swap and deal with all the headaches of making it work with the 6.7 ECM?
I agree, I think the 68 is worth modding. Products will come out, its just a matter of time. So we all might as well start saving up. :w:Isn't Torqueflight a Chrysler trademark name for their transmissions or did Ford purchase the rights to use the name?
I would say that the 68RFE is worth modifying. Stock for stock they seem to be out performing the Allison when boosting the performance of the engines.
yeah I'm pretty set on going with Goerend or NADP for trans products.Yeah, but I think they are saying that, as long as these trucks have been out...and as many engine performance things have become available, you would've thought that by now someone would've perfected the 68RFE...
That's my thoughts...
And don't say that ATS has...I refuse to buy their products, so they don't count, IMO.
Tell me when Goerend, Suncoast, Jasper, or somebody like that has one out that will handle up to 1,000 RWHP...That's when I'll be happy.
