Mark Ward
Ok, I finally got my truck all together last nite and fired it off. It idles like its supposed to and sounds great. BUT when you give it the fuel, it will idle up fine and then when you let off it will hang around 1400 and sputter a lil then idle down.
Ive checked all the connections, fuel lines, and IC Boots. I cant fiqure it out. and its drivn me crazy.
Thanks
Mark
I-C smoke just put one in..hell probably have the most to contribute here
Call Mike, pm me if you need the number.
who's injectors are you using????
Go for Broke
sounds like an APPS problem to me....did you do an APPS re-set?
MI Chapter President
x2 did you mess with the APPS sensor? check the plugs on it and cables to make sure they are working properly..... a good way to check is pull the plastic cover off the side of the APPS then rev the motor by hand and see if the APPS is working correctly..... check for codes as well:thumbsup
if that doesnt fail call Mike... his number is on VPMONSTERPUMP.COM
Ian
