21 - 40 of 45 Posts
CONTACT J KIDD AT DIESEL AUTO POWER ALL HIS PRICES ARE LISTED ONLINE.
THE S300 IS A D-TECH AND THE S400 IS A HOLESET. I THINK
Discussion Starter · #22 ·
I thought they were borg werner...or the schwitzer brand for the diesel guys...correct me if im wrong
:confused013: Forgot what he told me.
Discussion Starter · #26 ·
So the s300 s400 combination along with the fuel would get me to 600 hp with my SO pump?
if your looking for a good pump go through bluechip. There pumps r great. Great mileage and can support at least 700hp. Cant go wrong with their stuff.
yes anything with S in it is a schwitzer turbo. anything with H in it is a holset. these are generally safe assumptions. HX40=holset. HT3B=holset. S362=schwitzer. S475=schwitzer. Schwitzer turbos are more robust, efficient and expensive. There are still some good holset set ups but in general for big singles, schwitzer is where its at.
Reactions: marine3521
i am running the ATS twins (3000/5000) and a hotrod vp pump and it made 666 hp. im prety sure i can reach 700 on fuel only if i can get the dyno to load the truck a bit more. im about 15psi down from what i see on the street. it is also a perfect setup for street driving there is NO lag and top end is great. this summer im going to put some spray on it and see if i can reach 800 w/ my HRVP!!!!
Discussion Starter · #32 ·
Do you like your HRVP44? I heard good and bad things about it also what kinda injectors are you running?
Discussion Starter · #33 · (Edited)
Discussion Starter · #34 ·
Would the monster pump be a good setup with twins? Or would my SO handle the amount of fuel i need?
· Hemi
If you have a good clean injector then it can be a clean setup. Kjpcummin's told me he can drive his truck with ~240's and a 66/73/16 (or 14 can't remember) turbo smoke free on the street. He said it spools up just fine too.
I'm going for 600hp+ with a Silver Bullet (66/73/14) and SDX ~240's
· Vendor
Twins will spool earlier, s300/s400 you can support 700+ HP. Price for both turbos and kit is not too much more than a single turbo from some of the more expensive places.
i love it. it fuels real hard and i think it works great w/ my drag comp/6x16 scheid's/twins. it has never skipped a beat. knock on wood
i am running Scheid 6x16's, Schied told me they are +300hp injectors. they are smokey and they haze alot but once bost is up the are fine. i drive around town w/ my box off and the copiolt off so the converter does not lock up.
Discussion Starter · #39 ·
So what size injectors should i run with my SO and twins? I am leaning towards ats twin setup
· Vendor
150+ would be fine.
21 - 40 of 45 Posts
