what kind of fuel pressure are you guys feeding you CP3's?
HOw high?
how low do you let it go?
stock lift pump in the tank you will see around 6psi, on the back of the filter head youll see around 8psi. i wouldnt let it go below 4psi. but also wouldnt push above 20 or so.
im running a fass 95/95 and im feeding 13psi to the cp3.
Banned
Stock pump 10 PSI. Full throttle w Edge and MP-8 stack sucks it down to about 4.
with my wirdog i am seeing about 24psi with my gauge in the top of the pump. i see it drop to about 19ish at wot.
Has anyone ever put an eighteen wheeler lift pump and filter/water seperator on there cummins if so what , how, and how much did it cost?
