1 - 20 of 71 Posts
The other guy has a 380hp 4500lb gas truck that's setup for racing. My Smarty is on level 9. I usually do a 5lb boost launch 2wd. I'm New to the cr. I know the mega makes it heavy and I don't believe the big tires help either.
vvv SOME PEOPLE'S KIDS vvv
EFI live .
I believe my tranny is maxed out. But yes in the future!
Whats the question?
Would 450hp be real close to me right now. High? Low? No?
How will I compare to the other truck?
Your setup currently im fairly sertain he has you beat. Idk what those smartys put out but a 380hp gas truck built and set for racing unless you were doin a good 40 role you would need atleasr 500 to scoot that mega on 35s. What gears do you have 3.73?
A good tuner can build a tune that will run better then smarty and be easier on your tranny then smarty.
Your truck is what stock? Take about 15% off of that because of stock tranny and tires. Now take 20% off whar they clame the smarty adds and add that to stock hp.
2k at 70 with 35s id say 4.10s. :confused:
Discussion Starter · #14 ·
How would you add the 62mm phatshaft in there vs if it was just stock?
Prob not but maybe. I haven't looked at the newer trucks much. Id say it would b under the hood behind the grill.
Your stock turbo would have supported the smarty easily so I don't think that freed up any power.
If anything it barely helped. At MOST 25 hp.
Let me help you out. I have a buddy with a 01 f-150 single cab short stepsidd looks identical to a lightning. He is about 400hp and runs a 12.5 quarter. Can you come close to a 13?
Id say if lucky mid 15s but I don't know a whole lot about cr's
1 - 20 of 71 Posts
