1 - 20 of 24 Posts
so I've been chasing this god awful highway vibration for the last two years, I've tried everything. I can feel it in the floor and in the seat, the passenger seat shakes like a vibrator when going on the highway. doesn't matter if I put it in neutral going 55+ it still shakes until I go below 50mph, I've jacked up the rear and ran it and it still vibrates.
here is the list of things I've done to it: New tires and wheels (had one bent wheel) rebalanced about a dozen times. new ball joints, new steering stabilizer shock, new axle shaft ujoints, new brakes and rotors all 4 corners.new shocks, Rebalanced/rebuilt rear one piece aluminum driveshaft. I'm at a loss with this thing. any help would be great!
Discussion Starter #2
and I've also took off the front DS and ran it, its still vibrates.
If the vibration is "harmonic" like a massage tool then its driveline related or engine related. If the vibration is wobbly and shaky then its tire, rim, or brake related. So know which type of vibration will help understand what to look for.
its more of a wobbly shimmy I guess you could say.
Have you replaced the track bar?
Just curious what tires did you have and what did you replace them with? And what size? Some times hard hard to balance and some are just junk and need replaced even though they are new. I've had a few that shook from day one.
Have you rotated your tires? Does the vibe go from floor/seat to steering wheel?
Then its not driveline related...
You said you have new tires, so was the vibration exactly the same or did it change at all? Meaning, did the vibration change at certain speeds or feel any different or was it no different with old tires vs new tires? My first reaction was to blame it on bad tires but new tires should have solved whatever that could have been. But...if the tires are low quality and/or the tire shop has equipment which isnt calibrated right, or the techs are just lame at their job, then it could still be tires even though they're new.
One rule of thumb for tires is when they roll on the balancer there should be little to no movement. I wont take a tire that has a 1/4" of tread movement. Then if the tire has more than 1 oz of weight per side, that would indicate a problem. Either tire is not round of something else is wrong. I've seen shops put 3 oz on one side of a tire and call it good. Thats bad...
Reactions: walterjn
Discussion Starter #8
No, I don’t think that’s the problem. I’ve checked it and everything is tight. I had someone move the steering wheel and I got underneath it. Nothing is loose
Discussion Starter #9
315/70/17s falken at3s and yeah rotated every time time I got it rebalanced and vibration is always in the seat and floor. Nothin in the steering wheel
Discussion Starter #10
Had the same exact problem with the previous set of tires (Toyo ats) I’ve had three different shops inspect and balance them two of which I watched them do it and none of the tires were that far off. I can’t remember off the top of my head how much they put on.
When I had General Grabber ATII, my truck vibrated too. I had to road force balance to help identify the bad tire. Fought this for 2 years bc this eventually happened with all 4 tires (which General would only prorate as they went out-of-round individually...not the set). The 5th time I sold the haineous tires and bought Toyo due to the reviews here. I've never looked back.
I've had 3 sets of Toyo ATII and current Xtreme's and they balance great and thankfully no vibrations.
I would recommend having them road force balance to see if they are out of round. I cant remember what General said was the magic prorate weight number but I had to have roadforce first to confirm the tire took too much weight.
Anyway, Best of luck and keep us posted.
I have put five and more ounces of weight on one side and called it good. Because it was.
The amount of weight required is a really poor way to judge how well a tire will run down the road.
Actually, I'm still surprised how often the tire with the most weights has the lowest road force.
Discussion Starter #13
Yeah I’ve been thinking it’s the tires the whole time but just didn’t make since because the vibration was there even with the last set of wheels and tires. But I will look into getting them road forced and keep you posted! Thank you!
Even the slightest out of round tire can be felt. If I aired up my tires as recommended...I could always feel it more it seemed. By airing it down helped the jarring some. I would keep about 40-42 pounds in the rear and that did help.
Discussion Starter #15
so I finally called Les Schwab and had them road force my tires, they called me and said all 4 were out of balance ( I just had the place where I bought the tires " Rebalance" them 4 days ago") and the one rear was 48lbs! the other 3 were good, so they did the best they could and got it under 30 which he said was the acceptable limit. and now it drives smoother up to 60mph
That's great news and glad you have it resolved.
Thanks for updating us;)
Discussion Starter #17
Thanks for updating us<img src="http://www.cumminsforum.com/forum/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" />
Thank you for the input as well!
Years ago I had this problem with a Dodge van. There is a tail shaft bushing on the Torqueflite that was the culprit. Luckily I was able to drive a new one in without removing the old one. I am not familiar with the new trannys so I can't tell you how to replace the bushing but that's what I would research...I read that your problem was solved, good, my solution would not have helped since you have a 4x4. There should be a bushing where the driveshaft goes into the T-case, I don't know if a worn bushing in the T-case could be a cause for vibration
I had the same problem with my toyo tires. Three were good and one was way out of round. It took another two tires to get one that was still in spec. Went to Michelin defenders and it’s smooth as glass.
1 - 20 of 24 Posts
