You will also need the bracket for the 2013 pump. It is under $20.
You will also need the high pressure line from a 2012 that goes from the pump to the hydraboost. This will give you an oem fit and finish. $100 from dodge.
The 2013 power steering pump fluid reservoir. $70
18" of 3/4 hose approved for atf/power steering fluid (fluid supply line to pump from reservoir)
18" of 5/8 hose (fluid return line from cooler)
I did this to both of my trucks as well as the 6 bolt steering box from dodge.
The Mopar 2013 pump comes with the pulley already installed on the pump. The pulley from the 06 will not work on the newer pump. I also recommend replacing the other high pressure line hydraboost to steering gear while you are in there. As well as flush the cooler. This setup also places your fluid reservoir in a way better spot for adding and checking fluid levels. I got the high-pressure line that goes between gear and hydraboost from rockauto.com
