đź‘‹ Welcome to the Cummins Diesel Forum
2019+ 4.5 Gen Ram 6.7 Cummins
2019+ “5th” Gen
2013-2018 4th Gen Ram 6.7L Cummins
Late 4th Gen Trucks- All with DEF
2010-2012 4th Gen Ram 6.7L Cummins
Early 4th Gen Trucks- Non DEF Pickups
2007.5-2009 3rd Gen Dodge 6.7L Cummins
DPF Equipped 6.7s
2003-2007.0 3rd Gen Dodge 5.9L Cummins
The High Pressure Common Rail 5.9s
1998.5-2002 2nd Gen Dodge 5.9L 24V Cummins
The VP44 5.9s
1994-1998.0 2nd Gen Dodge 5.9L 12V Cummins
The P7100 5.9s
1989-1993 1st Gen Dodge 5.9L 12V Cummins
VE pump 5.9s
Other Non-Dodge/Ram Cummins Applications
If your Cummins is in an HD truck, RV, Boat, etc, then this is your section!
Conversions - ShopTalk - Tools&Boxes - Fabrication
NO ADVERTISING
Discussion of the Cummins Conversions and Fabrication Needed to Complete. Talk about and show off your Tools - Tool Boxes & Shops. Show off your General Fabrication Projects
General Forums
Specialty Forums
Technical Articles - Writeups - Guides Section
Forum Resources
Marketplace
Member for at least 10 days with a minimum of 20 posts required to access
Vendor Member Section
Want to Grow Your Business? Learn more about becoming a Supporting or Premium Vendor
Regional Forums
Forum Support
Community Hall
Latest Posts
In the morning when it's cold or wet out the wiper intermittent positions don't work at first but eventually start working once the truck warms up. The module plastic near the connector shows signs of melting but I think the module is working properly and maybe the connector pins are not making...2 replies 137 views
I’ve perused the forum for an answer. My issue the cruise works, the lights come on when I start it. The 20a fuse is fine. The relay is not clicking, I replaced with another relay and still no dice. I don’t think it’s the clock spring, I haven’t pulled the airbag to see if the horn wires are...1 reply 69 views
My head hurts from trying to find a simple explanation regarding Diesel Fuel and the different types. Living in California (blech) I'm seeing more and more gas stations with diesel pumps that have Biodiesel and different numbers. What's it all mean Mr. Wizard? I thought I had to run Diesel #2...67 replies 2K views
