1 - 4 of 4 Posts
what parts do i need? and can i use my 13" sb con fe that i just bought for my 92?
Discussion Starter · #2 ·
bump....know one done this?
You will need to go with an adapter to run your pass side drop T-case for sure. Your clutch will work fine but you will need the slave and everything from the pressure plate back I believe. But the engine adapter is the same as well as the input shaft. If you're planning on pulling with this though I would run the 4500 because you can get the larger input. I know the X members will also need some attention.
There is a guy on the DTR that has done this. Maybe try and post it up over there to see if he'll chime in.
You can get the larger input shaft for the nv5600 to... And in billet! I got mine through Jbarker and i beleive Valair is the Manufacturer
1 - 4 of 4 Posts
