soo i got my engine now if i remember right there were some cpl that had block problems? any thing else i kneed to know? also i red some were that some injection pumps were better for upgrades then others?
and when i got the engine and trans the guys said the engine rand awesome and the trans had a problem shifting into high gear. any idea on what could be the problem? and im wanting to convert the trans to a manual od/lockup using the hobs switches. any thoughts on that? thanks guys
i put my engine vin in at cummins northwest quickserv online and came up with this
BASE ENGINE INFORMATION
Upfit Original
Engine Serial Number 56158814
Shop Order # SO98911
Plant BEX - B-SERIES EXPANSION SITE
Build Date 10 Jan 1994
Warranty Start Date 10 Mar 1995
Customer Number 1386
Customer Name NO WARRANTY COV
ECM Code Not Available For This Engine
Fuel Pump Part # 3921918
Fuel Pump Calibration G330
Film Card T
Engine Config # D403029BB01
CPL # CPL1549
Model Name B5.9 (160)
look in the tech section for the TC lock up switch. Im fixin to put one in my truck today
As for the engine any cummins with a p-pump will make power you just got to put in some work.
Your 160 pump and injectors are not going to be great for free power, but the 160 pump is also a better starting point if you want to make big numbers. The best engine for free power would be the 215hp 96-98s as the pump flows more fuel and the injectors are bigger. but the 215hp pump has its limitations in high hp applications due to its retard notches in the plungers.
thanks for the reply. but i should have stated earlier that the engine is going into a 79 plymouth trailduster
http://www.cumminsforum.com/forum/c.../147335-project-cummins-trail-duster-ctd.html
and i am not going to use the factory wire harness or computer. so i wanted a way for it to shift into overdrive and lockup the converter with out the computer
also did a little looking came across the power kit at tst products. any one use their power kit? it puts my power desire right where i want it. bout 230 hp and 600 tq. is there any adverse affects to the pump or engine other then big power numbers?
You should be able to get that out of it at least without spending a dime
CumminsDatabase.com :: Turning Up A P7100 Pump
No adverse effects on the pump, but when you start adding fuel you definately want to watch EGTs and boost for safety. Im not sure how much that car weighs but im sure its lighter than a 8000lb+ ram so its likely that a bit of extra fuel isnt going to be much of a concern at all.
As for wiring up the TC and OD. Why not just use a dodge ram PCM?
They are a very simple system and it controls the grid heaters/charging and trans functions. I would try to rig up a PCM if at all possible. Save having to f-around with manual OD and lockup switches.
well the other guy who did the conversion said his truck weigh 7046 pounds.
i dont use the computer cause i dont like computers on my vehicle. whole point on using a mechanical injection was to keep it simple. that and i dont have the complete wire harnes just the parts that were attached to the engine. they cut the rest off.
and from what i understand an a618 (47rh) is just an a518 with a lockup tq converter. and i seen people use hobbs pressure switches for it. was just wondering if anyone actually done it on here
Dodge 727 Transmission Swap to 518 Transmission from PATC, 46RE 47RE 48RE
