empty posi carrier 3.73 down
DANA > DANA 80 > POSI L/S > SP 75352X
loaded posi carrier 3.73 down
DANA > DANA 80 > POSI L/S > SP 708054
i have 3.54 wanna swap!!!!I've got 4.10's in my 3500. Looking at swapping gears since it's wound up tight at 75 mph which is the speed limit pretty much everywhere in South Texas. Was checking out Yukon gear, and the prices are pretty reasonable, except I can't find a 3.73 series and up positrac carrier. All i see is open carriers. Can you put posi trac in the open carrier after the fact, or even a lock right? Thanks for the help.
That heavy of a truck and towing too..RPM's at 75 are right at 2500 rpm. I looked at bigger tires, but that requires taking the firestone air ride off so i don't hit the bags, plus lifting the truck because of the skirted CM bed i have on it. Truck weighs right at 12K with air compressor and welder on it, plus 8k in the gooseneck. Add on a backhoe, and i'd like to be able to downshift to 5th gear and run direct instead of beating on overdrive. Thanks for the link to the carrier.
Back to the open carrier idea. Anyone run a Richmond gear lock right or powertrax. Looked into a open carrier with a Lock right. Gonna be right at 650 or so, which is cheaper than the positrac carrier posted above, and theoretically stronger?
