can any one help
3.73 is what is stated on the tag in the glove box. So that is what im baseing what is in the truck. I allready have larger diameter tires than what comes stock. So with out having to tear my front and rear covers off. How can I find out what is truely in the cases.Based on the information that you have provided, it seems like you have a 4.10 axle ratio instead of a 3.73.
If you want to lower your rpms at any given speed, you have two choices: First, you can use a larger diameter tire. Second, you can change your axle ratio to a higher ratio(numerically lower).
:hehe: Well I do like to at least drive the speed limit. Yes, highway fuel mpg is not where i would like it to be. A diesel gets it best fuel economy normally around 1900 rpms. So that is why I am trying to drop the rpms.My suggestion......drive slower Ha Ha.
Good call. I just took it for granted that he would have corrected his speedometer, or taken the speed difference into account.if your tires are taller than stock, u are going faster than your speedo says...
