I just had an after market stereo system installed on my 2003 Dodge Ram turbo diesel Cummins. Ever since then the battery guage, fuel gauge, and the speedometer doesn't work. Also the parking brake light stays on even though it's not engage. The abs and engine light is also on. Someone suggested that it might be the ecm. I'm trying to find a wiring diagram to find out if the instrument cluster wires are connected to the ecm. Need some help here.
Trying to learn
Was it broken when you picked it up from install?
Hopefully, they unhooked the batteries before starting work on it, could have shorted something.
Try unhooking all 4 battery cables, then let it sit for 1/2 hour. Be sure the post and inside clamp are clean/brite before the reinstall.
Reactions: rghavana
Trying to learn
Again, Was it broken when you picked it up from install?
For the wiring diagram get FSM here.
Reactions: rghavana
Yes, it was broken after we picked it up from having a stereo system and subs installed. Worked just fine before that. I've been working on the truck after work and I'm finding some very poor connections. I'm hoping that's it.
Trying to learn
You should be making them foot the repair either way. I would have been right back in there before ever making it home.
Reactions: rghavana
