1 - 12 of 12 Posts
My mom decided to help clean out the garage by pouring one of my gas cans into my truck. She got about half gallon of gasoline 87 oct into the 33 or so gallons of biodiesel i have in there should i worry about anything?
i would.........gas and diesel doesn't sound good. :CRY::CRY:
Even if it is mixed in there at that low of a ratio??? Its a 1:528 roughly.
Mod Maniac
na....run it, all is good
With that small amount of gas in that rather large amount of diesel... well if it were a VW diesel I'd say don't worry about it. I'd just fill the tank when it got about half way down. I'm still learning about Cummins diesels, but I can't imagine that they are that much different.
RUN IT. No worries.
nothing to worry about dump some oil in for extra lube and your golden
dad used to run a fuel buisness, he said that 1 to 100 was safe, i guess some old loggers used to do that to help prevent gelling in the cold weather.
it should be fine but id put some 2 stroke oil in there to add a little lubricity
Discussion Starter #10
Phew I really dint want to have to loose my 33 gallons of gold. I dumped in a pint of 2stroke so between that and the Bio I should be good. Heh at least my injectors are gona be clean.
My brother in law still mixes gas in the winter for his over the road trucks. These are new Freightliners. He says it helps gets back the power and MPG loss from the winter fuel. He always runs them a million miles and trades. Never had a catastrophic failure.
We obsess over our trucks because they are our hobby, but when you get down to it, a diesel engine is a pretty darn tough piece of equipment.
1 - 12 of 12 Posts
