Hi Jeff,
Had this happen on my 99 also, took it to the stealership said it was the sending unit and could fix me right up for $525. I said thats ok I"ll pass 7 years later the turbo boost sensor went out. Went to my mechanic that now does all my work fixed me up for $55 this was to fix the boost, everything worked fine for 2 days including my fuel gauge. I then got the boost code again he fixed that when asked about the fuel gauge it was a wire that runs along side the lift pump that shorted against the bracket.
