1 - 1 of 1 Posts
Will a gauge cluster from a 1995 gas ram work on a 1995 diesel ram? From looking at pictures the gauge clusters look exactly the same.
Do the 1995 gas rams have the same dashboard wiring as the diesel? I think the only differences are the lack of a wait to start and water in fuel light which could be wired to lights separately. I'm not sure if the gas dash wiring harness is prewired for the wait to start light and water in fuel light.
I have looked at part numbers and the only part of the gauge cluster that is different is the temperature gauge (starts at 190 and goes to 260) and the tachometer (goes up to 6000rpm I think) The connections on the back of the gauges look identical to the diesel gauges. The ignition switch on the gas is compatible with the diesel as well as the headlight switch and turn signal switch. The vehicle speed sensor that is on the transmission is also the same on both gas and diesel.
1 - 1 of 1 Posts
