garrett stage 2 or 3 or aurora
im looking into the garrett powermaxx turbos like the stage 2 or three? anyone had any experience with them ? im running a hot rod pump with 100 hp injectors edge comp box stacked with the smarty and fass fuel. ive got a dd clutch on the way and was plannin on ordering studs at the same time. im hoping for about 50 psi boost at least?
or i was also looking into the aurora 5000 as a cheaper solution?
i dont tow much and if i do its 10,000 lbs at max
im up for any suggestions
i have the stage 2. i got a new comp box on the way so ill let you know how the egt's are. max boost i have seen thus far was 36 psi with the quad and egts were at 1300 on a long pull. i tow roughly 7k car+trailer and it has no problems. egts get to 900-1000 and stay there no matter what. ill tell you it lights pretty damn fast when i had the quad, now with just the smarty it doesnt seem to go as quick. i still have the stock air box on it though. i did open it up a lot, but i think the k&n pannel just cant flow the air needed. that turbo does sound badass when lighting up and cruising at 5-10psi
Got P7100?
Ive got the stg 3 on the truck i just got, it lights good and pulls strong. THe A5k would prob be too big for your setup, but any 62mm charger would be a good option for your setup.
so maybe like a 62/71/14? or 16? or what about an a4000?:confused013:
Got P7100?
The 62/71 for top end power, 65 for quicker spool and better bottom to mid power/14 would be a great charger for you. Dont know the sizes for the 4k, so i cant help with that part.
so what do you think about the suber b special i know its a 64 and its gonna have a bit more lag but for the boost im wanting im guessing im gonna have some
Got P7100?
The special will be laggy with the 100hp sticks. The 62 is good for 100-150hp sticks with a low egt, some guys even run 200hp sticks on a 62, but im sure it gets hot at wot. 64s are usually ran with a 150-220 hp injector(on our second gen 24valves)
Remember boost # is just a measure of the pressure waiting to go into the engine, it does have a lot to do with the amount of power you make, but airflow is much more important than overall boost #s. You could spin a 62 or 64 up to the 50psi, but the 64 will be moving more air at that psi than the 62 will. I would run the 62 if you dont plan on going to a bigger injector, imo a 150hp injector is the smallest i would run with the special.
