I just installed a temp gauge on my G56 trans in the PTO cover after changing the fluid to Amsoil ATF. While on a fairly easy tow with my 12K LB 5th wheel in 60 degree weather, the temp got as high as 200 degrees. Has anybody else seen this? A cooler and filter setup would be fairly easy to do if I can find the right pump. Any suggestions would be appreciated.
