My truck was an auto but had a g56 conversion done. Now I'm trying to hook my reverse lights back up cause I can't see anything at night backing up. Anyone know which wire it is coming off the harness?? Thanks in advance
If you look at the harness above the crossmember on the drivers side pull the woring out of that harness and find the white wire with light green tracer. Run fused ignition hot power back and hook it to the one side of the reverse switch and cut that white wire and run it to the other post on the reverse switch and you now have reverse lights.... Again the harness is runinng down the drivers side frame rail and you can tap in right above the trans crossmember
