Sure can. I heated mine with a torch, bent it, and cooled it probably 20 times before I got it exactly where I wanted it.What is it made of, can I weld it? Can I heat and bend it.
Heat it first and it bends like butter! You can go 90° with it in a tight radius with no cracking at all...I was trying to bend mine in a press, and I cracked the lower part.
I have the same cup holder, I got it at Genos Garage. Here is a link.OK, please tell me where you got the extra cup holder??? it fits so perfect......:yourock:
I would not mind known where the shifter knob came from either...
Later
Yep GenosOK, please tell me where you got the extra cup holder??? it fits so perfect......:yourock:
Later
Where's the shifter from
Hurst 1531000 Universal Pistol Grip Shift Handle : Amazon.com : AutomotiveWhere did u get that pistol grip shifter
At the topwhere did you weld in the extension at. I have the cup holder from genos garage and I wanted to extend my up higher thought about buying a new one and replacing it with a longer section thanks
