I am experiencing a “problem” with my truck, which I have since new and after deleting. When I’m playing around and romping on it, the truck seems to almost die or a second between shifts. It’s most relevant in the funnest gears,from 3rd to 4th. It’s extremely annoying especially if I’m trying to burn money(tires) and I can’t keep the tires spinning between the shifts because I loose all boost and power. Rail pressure dips a bit. Is this a stock lift pump problem? Not being able to keep up? In the near future I will be installing a WCFab s467 and a lift pump, but I’d like to have the problem solved before I do this. Any advice would be appreciated
