Penetrating oils, some are better that others and a home brew is best.
They are below, as forwarded by an ex-student and professional machinist.
They arranged a subjective test of all the popular penetrates with the control being the torque required to remove the nut from a "scientifically rusted" environment.
*Penetrating oils ........... Average torque load to loosen*
No Oil used .................. 516 pounds
WD-40 ..................... ....238 pounds
PB Blaster ................... 214 pounds
Liquid Wrench ...............127 pounds
Kano Kroil .................... 106 pounds
ATF* - Acetone mix..........53 pounds
The ATF-Acetone mix is a "mix-your-own-brew" -- 50 - 50 automatic transmission fluid and acetone. Laquer thinner can be used in place of the acetone.
Note this "home brew" released bolts better than any commercial product in this one particular test.
Note also that "Liquid Wrench" is almost as good as "Kroil" for about 20% of the price.
