1 - 9 of 9 Posts
my window sticker for my truck says it came with a 10 gallon bigger gas tank then standard. the sticker said it came standard with a 22 gallon originaly but people say these trucks have 30 gallon trucks. i seem to sip on gas so do i have a 30, 32 or 40 or 42 gallon tank? thanks
its a 30 my 3/4 ton has a 25
My trucks are likely 20. When they are setting at about 1/2, they will hold another 11 gallons. At 1/4 they hold about 15 gallons.
My 3/4 has a 32
Or the filler neck holds more than I thought
The neck filler probably holds more than you thought, I'm 99% sure they are 30 gallon tanks. I think it was 93 or 94 before they switched to 34 gallon tanks and they never used a 32 gallon tank to my knowledge.
Pretty positive my truck is a 30 gallon tank as well.
In my 89 factory service book it says 30 gallons (or 68 liters) is only option on the 89's.
you might as well fill it up diesel is just going to get higher:CRY: this way you will save money and find out how much your tank will hold
Regardless of whether its 30, 32, or 34 - at these prices its a shame.
Most I ever put in my tank was coming up here to Mi from Tx...Low fuel lite came on ~ 1030pm in a snow storm. 1/2 hr later I found an exit with a station that had diesel. Gauge was needle width above E line...27.75 gal later and $37.50 ( this was over 3 yrs ago :CRY::CRY::CRY: ) I knew I had a large tank.
BTW - tranny was in good shape then and I cruised at 70 for 618.8 mi when I filled up...Best mileage I ever got.
1 - 9 of 9 Posts
