I've posted several questions regarding the fuel shutoff solenoid and it stills causes me issues. I have removed the rubber boot because it had deteriorated and I thought it perhaps was getting caught in the spring mechanism. I’ve cleaned the inside of the solenoid, the piston and spring and adjusted the piston rod length according to the instructions (with the key in the on position and pulling the piston up manually). The system works fine the first time, but frequently the rod will fall out of the piston after turning the motor off obviously causing the truck to not start. I've read until my eyes hurt trying to figure out why this is happening. Does the rubber boot provide a means for the rod and piston to stay together? Am I missing a spring somewhere else? I don’t see where anything is missing from the documentation that I can find (rod, piston, and a spring).
Hopefully, this is something easy and the truck does not hate me, or it’s time to put in a manual cable (Joe G mentions using a inner tube-does anyone have details on what that involves?).
Thanks,
paul
Thanks,
paul
