Ok, did a search, but couldn't find what I needed. Fuel shutoff sol will not pull up at all, and will not lock at all (even manually). Here's what I can tell you:
Solenoid works perfect if I jump it out to battery voltage at its' connector, no prob
Blue wire at the battery checked, not corroded, has juice after the fusible link
Shut off relay gets battery juice, but will not get anything to the other terminals when the key is turned on (same thing with the relay next to it)
Anyone have any suggestions? I have a CD with the trucks wiring diagram, but of course I can't find it right now.
