Hey so here's my issue, was my issue before when I was posting about not being able to get past 40psi. My fuel shut off solenoid was not lifting all the way, maybe allowing 7-10mm travel. Took it off cleaned it put it back on and now allowed full travel. However before it felt like it was even tho it clearly wasn't (felt like I could bottom out the solenoid) now I took my afc off today again to put a heavier spring in and I checked it again cause I felt I had lost some "uuumph" and sure enough not allowing full travel again, not as bad as before but still. And again I can pull it all the way up but doesn't go all the way back. Repeat what I did before and full travel again. I thought to adjust it but it was traveling all the way. Figured id measure it and put the key to "on" and lift it up as I'm told it should hold itself there but it doesn't? Could this be my problem? My dad tell me there should be a pull,hold, and ground and maybe the hold isn't working? Any ideas? Thanks guys!
Sent from my V8000_USA_Cricket using AutoGuide.Com Free App
