I just put a new injection pump on a 1990 non intercooled cummins. The engine starts and idles fine but wont rev more than a couple hundred RPM's. If I plug the fuel return from the injection pump it will run like its supposed to. Please any and all help and advice is greatly appreciated.
Discussion Starter #2
After several days of thinking and working on the problem I finally found my problem. When putting the injection pump and lines back on I mistakenly put a restrictive fitting in both the return line and the line leaving the fuel filter. There should only be a restrictive line on the injection pump return line. Hopefully my mistake will help somebody down the road.
Nobody seems to be giving you much attention, do they?
So you used a banjo bolt with a pinhole at the filter?
How'd you get a second pinhole banjo bolt?
Not nice of you begle to call him a pinhead.:lol3:
They sent one with the rebuilt injection pump and I still had the origional one. I guess if the bolt has out writen on the head than that means out of the injection pump not the filter housing. I cant belive I got these mixed up, I'ts like I was always taught that experiance is the best teacher it just hurts the most.
