1 - 4 of 4 Posts
Quick question guys
On top of the fuel rail is what looks like a check valve that returns to the stock fuel filter canister.
Is this a check valve that will only allow one way flow away from the rail or will debris get down threw it to the rail? What is the real name for it?
Thanks
Sent from my iPhone using AutoGuide.com Free App
I replaced the top steel/rubber washer with a copper/rubber oil drain plug washer from a parts house. Tried to keep debris from falling in.
Can junk get back trough the PRV to the fuel rail?
· MOLON LABE
i would think not. even if you somehow could put 30k psi on that side of it i dont think it works that way.
Reactions: jerrodlk
1 - 4 of 4 Posts
