I am new to diesels and purchased an 08 and am having trouble finding ultra low diesel in the area I work, what will happen if i run normal diesel? Thanks guys! any input on an intake as well would be appreciated!
Where exactly are you? I thought the ultra low sulfur diesel was mandated everwhere in the US?
It will cause you problems...Ultra Low only as recommended on the fuel gauge on the truck itself...
You can still find it at truck stops and such...It is cheaper than the ULSD at least here in Houston it is...You are supposed to run it in 2007+ vehicles...
Found out in canada all pump diesel has to be ULSD and doesn't have to be labeled because of only one grade being available, thanks guys
Here where I live, for now, I have only seen 1 Ultra Low. Most everything else is still #2.
