I don't see a link, but I run the BD auxzillary pump inline with the intank pump. 20psi at idle 14 psi wot. Been running it for 2yrs no problems.
i thought it was under my words...well thats pretty much the one its on ebay
I have been running it for almost two years 32psi at idle 12 at wot. A lot cheaper than a fass!
I thought BD made a lift pump that mounted in the factory location?
No, to the best of my knowledge, at least on the third gens, it is mounted on the frame rail and has an adapter so you can take out the stock lift pump. I believe it is the carter lift pump.
was it easy to install and did you have to take out your other LP? or just add it in..where did you put yours? thanks
