The fuel pump in the tank is not getting power to the plug, I have traced the wires and cannot find where the problem is comin from. I've had a couple people go over my work to make sure I didn't miss nothin and they're stumped too. The pump on the block runs when I crank it over, but the motor is not gettin fuel. The pump in the tank isn't kickin on or runnin. I had a buddy bring over his programmer to see if it'd throw any codes, well the plug bundle where the programmer plugs into isn't gettin power either. Can I jus run a hotwire to the pump to see if it'll run? Do the two pumps need to be wired together?
I jus got this truck last Monday and its been a pain in the since I got it. Idk if this helps but the kid I got it from said that when it'd get to half a tank of fuel, it'd start "suckin air" as he described. So basically you have to keep it above a half of tank for it to run. I was between 1/2 - 3/4 when I went to the gas station. I fill up, I get back in to start er up and she wont. HELLPPP!!
By the way..new around the site..
