1 - 11 of 11 Posts
I had a FASS system installed on my truck about 2 months ago along with a FP gauge. Every morning I'll start my truck and let it idle for a bit before I leave. Now I personally think the truck is idling high. Right around 950 in park and 800 in gear. But thats not what my main concern is, I've noticed lately the FP gauge jumps around from 10psi to 20psi until the truck gets warm ~30min. of driving. Any ideas?
Sent from my LG-E739 using AutoGuide.Com Free App
fp
you don't say whether it's mechanical or electric fp gauge [ it makes a diference] for proper info help. jim e.:stirpot:
I would have said the grid heater is the cause but it shouldn't cause a 10psi difference in pressure. Have you a mechanical or electronic fuel psi gauge?.
fp
i have a mechanical one on my rig. the fuel pressure flucuates probably 6-8 psi when warming up. i don't know why for sure but it probably due to the grid heater [drawing lots of current]from the system. just look at your lights at nite,they too flucuate a lot. at this point i don't think you have a problem. if it acts normal after warm up. jmho jim e.:stirpot:
Interesting. Guess I won't worry about it. Onto my other concern. Is my truck idling high? Its all stock.
i found out that it also could be caused by a weak lift pump. i had a low pressure and fluxuating pressure issue with my airdog when first started for awhile. got a new lift pump same exact thing just a replacement and it stopped bouncing around when first started now i see 2 maybe 3 psi flux max also when cold my truck idles around 850-900 when warm 750-800
· On call 24/7
Should idle around 800 all the time unless it really cold out.
on your idiling mine is at 800 rpm cold drops to around 750-775 warm . i have a 6spd man. so i would say no worries there. my raptor 100 is about 1.5 yrs young, about 6-7000 miles on it,relocated on the frame near the fuel tank. i'm satisfied it is working properly. :stirpot: jim e.
10 psi is a lot of variation. The grid heaters certainly draw a LOT of juice, but it shouldnt draw down the lift pump that much, and either way it should stop when the grids do. The heaters only run at cold idle, below 15-20 mph. Unless the OP is driving thirty minutes at less than 15mph, something is wrong. I would load test the batteries, maybe one is getting weak, or maybe the grids are cycling when they shouldn't. Maybe you have a loose connection somewhere in the gauge or pump motor wires that tightens up when it gets warm, making a better connection. Does the FASS have an internal pressure bypass in case of a completely plugged fuel filter? maybe its building up pressure, popping off etc untill perhaps the filter ungells? Do you buy your fuel from a reputable station with high fuel turnover? It might be worth putting some new fuel filters on there, maybe theve done their job and filtered out a lot of crud from a dirty tank. Its happened plenty of times before.
All Im trying to say, with that long and scary list of potential issues, is that pressure spike and fluctuations are not normal in a fuel subsystem. Whether its very simple or very complex, id investigate further. Its more than likely a simple issue, but why gamble?
Attaching a mechanical fuel pressure gauge, even temporarily, would help a lot in diagnosing.
Edit: probably not gelling since the OP lives in Cali. Sometimes you just get in an East Coast winter state of mind!
1 - 11 of 11 Posts
