1 - 18 of 18 Posts
I'm running the edge ez with the fass fdrp pump will this give me enough fuel pressure? I always use 2 stroke oil to keep the pump lubed up too?
It should, I'd still recommend a fuel pressure gauge to be sure
Where do you hook the fuel psi gauge up at?
I wuld deff recomend a fuel press guage. With the factory screw adjustment I culd suck it down to 5psi not even wot and around 15 idle. I adjusted it right away to 20 idle and and 7 wot. I dont like it at all tho. It dont flow like i thought it wuld. Any sugestons how to get it to flow more without upgrading? Is it worth it to buy a bigger line to go from fuel filter to vp for $30?
I hope that 30 kit will helps us out some!
I don't think a bigger line would make that much difference, could be wrong. I'd be worried to at anything under 10psi (and I still really don't feel comfortable with anything under 14psi)
If a guy wasn't running enough fuel psi how long til the pump dies out on you?
Depends how bad it pressure was and other factors, but a gauge is cheaper than a injection pump
vulcan performance sells bout the cheapest fuel line from fuel filter to vp with the T fitting for a fuel press guage. $35 and maybe a lil more for ship.
fass DDRP is not enough for ANYTHING over stock. Even FASS reps will tell you this. DDRP pumps are for 100% stock trucks only. if performance modified in any way, DDRP can't keep up because it only flows as much as a stock lift pump.
Discussion Starter · #13 ·
Anything I can do to help this fdrp pump?
Discussion Starter · #14 ·
Otherwise the only option I have is to upgrade to something like a 150gph pump? But I'd have to have someone install that on top of the $400 for the pump
depends on your plans for power in the future...
anything stock to about 500hp a 95/100GPH pump can handle just fine.
over 500hp would be better matched to a 150GPH pump.
Discussion Starter · #16 ·
I don't have plans to ever add more power just my dd, but isn't the factory replacement pump flown2.5 times as much as the stock carter?
fuel pressure gauge will tell the whole story.
I would get one installed ASAP.
isspro mechanical 0-30psi with a needle valve and napa airbrake line will get the job done.
pillar or column mount it for a nice simple install.
long as you can stay above 10psi at all times, including hammering down with a load on the truck, then your lift pump is fine. but if it dips below 10psi, it cant keep up.
Discussion Starter · #18 ·
Alright thanks for your help!
1 - 18 of 18 Posts
