Hey can anyone help me with a electric fuel gauge holding 19 psi at idle then as rpm goes around 1800 and up it also goes to 35 to 40 psi? it has a napa cut off valve which is set at 1/4 turn to 1 1/2 turns out still the same psi it is on the banjo bolt on the pump, Thanks, Dewayne:confused013:
