has always ran a consistant 15 psi. now runs 15psi at idle, but drops down between 3-7 when driving. vp44 and fass fuel system were installed 3 months ago. maybe wiring or clogged filter?
:S:
i just changed the filter. same problem, but now it sits at 16psi at idle, still drops low while driving
Master of Mayhem NASFIG
it should drop some while driving but i wouldnt think that much with the fass pump since its supposed to be one of the best
Rescue Tower
How are you getting these readings. My bet is your sending unit or fuel pressure gauge have been beat to death because you didn't install a needle valve to attenuate the pulses.
yea that mite be it but it should also do that at idle or at least mine did
