Hey everyone. I haven't posted up here in a while, but I've been lurking. I just installed a set of Isspro gauges (Boost, Fuel PSI, and EGT) in my '01. I plumbed the fuel pressure into the side of the injection pump. I replaced the stock banjo bolt with the schrader valve test port on it with a tapped one for my fuel line. That's plumbed into a Diesel Manor isolator, then up to the gauge. My question is, what should my fuel pressure reading be at this location? Everywhere I've looked takes the readings at the bottom of the fuel filter housing. If need be I'll move the line, but if I can find out what the safe range is at the side of the injection pump, I'll leave it.
Thanks in advance.
Thanks in advance.
