Get a FASS 95
My 250k factory pump has been eating this for quite a while with no issues....Can anyone provide published data on PSI numbers? A VERY well known diesel company told me anything over ten is great-no worries. I was also told too high would kill the pump. My pump is at 290k so I must be ok.
The over flow valve opens at 14psi. Not sure what else you need to know when it come to the health of the vp44 since it is cooled by fuel.Can anyone provide published data on PSI numbers? A VERY well known diesel company told me anything over ten is great-no worries. I was also told too high would kill the pump. My pump is at 290k so I must be ok.
Enough said.Approximately 70% of supplied fuel is returned to the fuel tank. The valve opens at approximately 97 kPa (14 psi).
So at 14 psi my fuel is going back to the tank... How is that cooling my VP? Nowhere in the FSM does it point blank say what pressures we should have.....Right out of the Dodge FSM...
Enough said.
Now as for the 70% return you need a lift pump and plumbing system to supply at least 90 GPH. To meet the 70% rule under WOT operation. Anyone with a live data tool can measure the flow to the injectors (30%).
For a near stock truck like yours....pretty legitimate guesstimation.Right out of the Dodge FSM...
Enough said.
Here is the minimum by the FSM. But its flawed...So at 14 psi my fuel is going back to the tank... How is that cooling my VP? Nowhere in the FSM does it point blank say what pressures we should have.....
I never burnt up a pump. I run a FASS 150 and always have 14-17 psi . I'm not sure where your going.....I have 290k on this vp. About 280 on stock lift pump before I got a FASS. This crap is overrated and blown way outta proportion. It does happen.Here is the minimum by the FSM. But its flawed...
I tend to look at the Bosch's spec more with the overflow valve and keep the fuel flowing under the electronics and keeping them cooler. But hey if you like throwing money away and burning up VP44's that your choice, your truck and your money... But please don't come back here and yell about how crappy the VP44 pump are. They work just fine if taken care of properly!
Take notice to the divided chambers and the direct fuel contact to the bottom of the PSG circuit board. So when the overflow valve is open >14 PSI then the fuel is rapidly trading heat away from the mechanical parts and the PSG electronics of the VP44. The backside of the PSG is also aluminum so perfect heat sink to fuel!
