CC,
I just got through mounting both the 30psi on the fuel lift pump for that end of the fuel system and the fuelrail pressure guage for the other end. I just knew I needed to do this to see how much I was running out of fuel on the 6.7...
Now mine are both electric units and I got the fuel sender unit in a 1/8"NPT for the 30psi unit and put this right behind the 2 micron filter I put in the system in front of the tank.
The fuelrail system plugs into the sensor on the back of the fuel rail and then the OEM plug goes into the other side of it. Then you hook up on both units the switched B+(12V), the chassi ground and then a running light switched power that is not the dimmer wire. I got all this under the dash and right under the white plastic cover where all the wires gather and go through the firewall. The plastic cover snaps on all four corners. The ground I drilled the aluminum frame work under the dash.
White wire with a gray trace is the running lights switched power that is not the dimmer circuit...
The switched B+ circuit came from a smaller red wire that I will have to get the color of the trace on if you need that also, sorry I don't remember the color of the trace off the top of my head
I see 9psi at idle and 6-7psi on a hard run. Rail pressure is 3-5K at idle and 24 at wfo, at least for now. I have only had mine all working today so more info later. I used the Autometer 2" cups to mount mine on the pillar right above the height of the Attitude on the dash. Dipricol-white face guages look really nice and like the OEM units day or night.
